Spanish v2 documentation update
An updated v2 Spanish language translation from David de las Heras is now available.
This contains translations of the new stuff for MoI v2.
You can browse the new Spanish command reference online here:
http://moi3d.com/2.0/docs/moi_command_reference_Spanish.htm
Also there is a PDF version available for printing here:
http://moi3d.com/2.0/docs/moi_help_Spanish.pdf
And you can also download the command reference to update the help file with the installed version of MoI, to do that download this file:
http://moi3d.com/2.0/docs/v2_Spanish_update.zip
and then unzip and copy the .htm files into the \docs sub-folder underneath MoI's main installation folder, and there is also an updated SpanishStrings.txt UI strings file that you can copy to the \ui sub-folder to update a few UI strings.
These links are also available on the Resources section of the wiki now.
Thanks very much David for your translation!
