Remove Save (etc.) from right-click repeat?
3674.9 In reply to 3674.8
Hi NightCabbage, if it works for you then go for it! :)
Some of those could potentially be problematic as a default setting for MoI, for example being able to repeat import could be useful if you want to import a few different times in a row.
But if you find it getting in your way more often then you should add it to that list, I made that list customizable so that you are able to tweak this behavior to whatever works best for you.
