WHat level of acuracy are you needing. I can set you up with a method to do this, but accuracy will be lost to some extent.
There is a script that will create "Line segments" between points at a set tolerance. You could then run the "Rebuild" command on the joined segements with the "number of points" option to create a single spline. To have a tight tolerance, the curve would be heavy on points and sharp corners will get a small "Wavy Factor" to it....
Post a file...
