Thanks for the explanation. I will contact the author of UV Mapper to see what can be done. For the time being what would you suggest regarding that value given that I need my models to go out to a customer using Max?
I'm glad at least that the obj format can be fixed in a text editor.
BTW, your obj merger is a wonderfully handy little tool. I can now do the same job in Simlab Composer (as promised, they have added an option to disable automatic snapping of imported objects to the scene floor) but I'm still using your tool to do the job. It is so easy to just drag the files into your tool's window and hit the generate button.
Mark
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html  |
