Hi Steve,
> Cut2D says "Failed to import vector data from EPS/AI/PDF file...
> The file probably contains only bitmap data." Not sure why.
It could be possible that Cut2D only reads newer-style AI files which are the same as PDF.
MoI writes the AI v8 type files. With Illustrator v9 and higher there was a big change in the AI file format to become PDF based instead of how it was previously structured.
Some programs only read and write the older style files since they are more simple in structure, but some other programs only read and write the newer style PDF files.
