| Hi Max,
 > Thank you Michael, I already experimented with the Isect command and it works fine for sectioned
 > elements, but what I need is to project the elements that are far away from the line\cutting plane
 I guess I need a more detailed explanation from you - I'm just not familiar with the type of sectioning that you need. What kind of additional projection do you need, can you post an example with some simple objects?
