Filleting Problem
3608.5
Hi Steve
I made the block at the front a simpler solid, I would cut out the air scoop after with a boolean difference. Also if you a mirroring make sure the 2 control points near the border are horizontal or you will have a crease when you mirror (see attached picture. 2 highlight point should be aligned). This is the same with your other profiles. also make sure your profiles are aligned at the center Z axis. Its worth checking before you build you shapes because if they are out you will run into all sorts of problems later on.
Hope it helps a bit. Looks like you will also have a tough area with the wing transition, good luck. Look forward to seeing the progress.
Jamie
