Hi Steve,
 > I think overall that MoI is no good for my work,
 > MoI output is not accurate enough and when the
 > models are taken into the other packages I use there are many errors,
Just curious, what other packages do you use ?
I use NX6 at work and I have done various models in MoI with quite good results when importing into NX, we work to an accuracy of 0.005mm(0.0002") and 99% of the time the models from MoI pass the tolerance check amongst the other surface checks which do well most of the time, if a surface does fail it doesn't take much to fix.
I don't know how complex the models are that you are bringing in from MoI to your other packages but  this model I made 2 years ago in V1 passed the tolerance check at 0.005mm, there were a couple tiny objects and a couple of self intersections which where caused by the fillets which took me no more than 5 minutes to fix.
I believe working below an accuracy of 0.005mm is impractical in the real world unless you're into nanotechnology which is an entirely different world altogether.
If your getting a lot of errors with your models maybe try another modeling technique, like, I found I get better results if I use basic curves and arcs where possible instead of a freeform curve where you don't know what degree it is or how many segments it has.
I actually purchased MoI for home use and truthfully, I didn't expect a super accurate solid modeler but in the end it has preformed better than my expectations, I can even say it does better in a lot of areas than some mainstream CAD modelers that cost 10 to 20 times more.
~Danny~  |
