Import for Inkscape
3574.2 In reply to 3574.1
Hi dedmin - both of those formats are actually quite potentially complex, MoI will only try to read subsets of those kinds of files.
EPS for example can contain arbitrary Postscript programming code in it - to actually do a full job of handling EPS means to implement a full Postscript program interpreter which is a lot of work. MoI only tries to read EPS files that use a few relatively common kinds of instructions.
PDF is also complex in different ways from that, the PDF file is segmented into numerous kinds of sub-objects some of which are compressed and stuff like that. It's pretty hard to deal with.
Your best bet is to get your drawing in to .AI version 8 or earlier format (Illustrator v9 and higher AI files are actually the same as PDF), that is a much more simplified and structured drawing format which is much easier for MoI to process.
Try Mayura Draw as a helper program for this: http://www.mayura.com/
You could try loading SVG into Mayura draw, and then exporting from Mayura draw as AI format which I think will generate the more simple AI8 type AI file which MoI will handle much better.
In the future I may be licensing a PDF library to improve the PDF import capabilities of MoI.
