> But actually you can even use your v1 educational version for
> business purposes - only students or educators can buy the edu
> version but you can use it for whatever work you want including
> commercial work.
Hnhf... Wow... I didn't realize that when I buyed the first version. Normally "educational" means "restricted in use"... that's really great! [*]
> > so those future version could tell from the key(s) if there has
> > been some educational or only normal versions in the history.
> > So maybe I "get stuck" ;) later because my first MoI was only
> > educational? Hopefully not (?).
> I have no plans to penalize you if your original v1 version was
> an edu version.
And this is even greater then...
> But if you are still a student, you can buy the v2 edu upgrade
> version from Studica, it's half off the regular v2 upgrade
> version. There is no restriction on the kind of work that you can
> do with the edu version.
And, combined with [*], still greater! :DD
Finally, thank you very much for the answers. My order has just been placed :).
With kind regards,
Red*Star
