Sweep Problem
3564.9 In reply to 3564.5
Hi armin, also probably a better way to get rid of those little lumps is to use the Rebuild command on your joined rail curve.
To do that, select it, then type Tab, then "Rebuild", then push Enter.
I did that in the attached model.
That helps to smooth out the small tangent deviations between the different segments in your original.
I used a tolerance of 0.001 units for the rebuild in this case.
