Sweep Problem
3564.2 In reply to 3564.1
Hi armin, sorry it's not very clear to me which parts you are sweeping.
The profile curves at the ends of the gray blue surface seem to be larger than it, did you sweep using the edge curves of the other pieces as the profiles, or cut the sweep afterwards or something?
Could you please post a simplified example that only contains the rails and profiles for the sweep and the sweep surface? That would make it easier for me to understand what you are doing.
> BTW, and I probably should create another thread for this, but is there
> a way to check if a curve is completely planar, without showing the
> points and snaping the mouse pointer to each one of them comparing
> the coordinate values?
You could go to a side view and use the edit frame - if you can't get a "flat" snap then it means you already have a planar shape.
In the future I want to have a kind of extended properties dialog that you could bring up to get more details on a shape, possibly whether it is planar or not could be there.
