Hello,
In my work I use Moi to convert iges files to obj and then import them into Viz 2007 for further processing.
My problem is I seem to loose the correct normal information of the object when I apply an UVW modifier to it in Viz.
My question is if there is a way to not brake the original smoothing when UVW modifier has been applied?
In this image you can see what the difference is without and with UVW. Upper is without(correct shading), bottom is with.
