| Hi Pilou,
 > Does Bootcamp not more speedy than Parallal Desktop?
 It depends - Bootcamp requires you to reboot your whole machine in order to use it.
 If you want to just do something for a short time in MoI and then return to other work, it can be a lot more convenient to use Parallels because it runs inside the regular Mac desktop.
 Running it under Parallels is less efficient than running it directly with Bootcamp, but if you have a new enough machine you should still be fine.
 If you're going to be working in MoI for an extended time and on larger sized models, then Bootcamp would be good to consider though too.
