CustomeDistance Script
3536.2 In reply to 3536.1
Hi Michael T - well you can change the number of decimal places shown by default throughout the UI by going to the Options dialog, under Options > General > Decimal display.
But it's also possible to change it only for this one command specifically instead of for everything.
To do that only to this one command individually, you have to change how the command's UI is set up.
The UI for the command is defined in the CustomDistance.htm file, and adding in a style="decimalPlaces:x" attribute onto that numeric input field that holds the distance will control how many decimal places it shows.
So for instance to make it have 5 decimal places, find the line in the CustomDistance.htm file that says this:
<td><input id="space" class="numericinput"></td>
And change it like this (added part shown in bold):
<td><input id="space" class="numericinput" style="decimalPlaces:5"></td>
After you do that, the numeric field for that command will show 5 decimal places of precision instead of the default setting.
