| Hi NightCabbage,
 > But, I guess if the commands are useful, they should
 > fit somewhere :)
 Yup, the current situation is only temporary. I'm going to try to find a place to fit them.
 > Maybe there needs to be a "Line Operations" category, where
 > things like trim, extend, and rebuild go?
 Well, unfortunately it's not quite so simple as that either - for example the Trim command can trim surfaces or curves, not only curves.
 So if it was only found in a "Line Operations" category, that would make it hard for someone to find it who wanted a surface trimming tool.
 Similarly at some point in the future I do expect for both Extend and Rebuild to be able to work with surfaces as well and not only curves.
