| Hi FiL, yes that's correct there is not a button for it yet. I have not quite figured out the right spot to put it in the UI - that's one of the problems with making a nice uncluttered UI, it sometimes takes a long time to design it well.
 One of the easiest ways that a program can lose its simplicity is just by adding in a whole ton of stuff so that there are a bazillion icons all over the place...
 So for now you have to launch this command by setting up a keyboard shortcut or by typing in the command name.
 In the future I do expect to figure out a good place to add it to the UI where it will have a button or be on a menu of some sort.
