| Hi rodney,
 You can draw a line perpendicular to your helix shape making sure it is intersecting the bottle surface, then sweep that along the helix, using the 'flat' option in sweep, then use Construct>Curve>Isect to create an intersection curve between the bottle surface and the newly swept surface.
 I've attached the file with those operations.
 ~Danny~ |
