No Key Shortcut...
35.6 In reply to 35.5
Oh yeah, you can change all the text labels in there to French if you want.. You may need to save it as a Unicode text file if you do that. I will eventually have a different way to change the text to different languages (with a string table), changing the UI directly won't work too well when I put out new beta versions, especially if I have done any changes to the UI. But you can give it a try if you want...
