Create round text
3488.2 In reply to 3488.1
Hi pp, you can use the Fillet command in MoI to round off edges.
But Text can be pretty difficult to fillet, it often times has sharp corners and compressed areas which are more difficult for fillet to handle.
MoI is not generally the best tool to use for making rounded text quickly for rendering, if that was what you were thinking.
But for pretty simple text Fillet probably should do it, for example:
> is it possible to automaticaly create round object from extrude
> object, created in MoI ?
No, extrude in MoI only makes things that are punched out in a straight direction.
You can use some other tools to make more rounded things initially though, for example using several profile curves you can then use Loft to make a surface going through them like this:
It sounds like you may want to be using a polygon modeler for the kind of stuff you are talking about, MoI uses a mechanism called NURBS modeling which works differently than that.
