Hi Jesse, are you all set up ok now then?
The keyboard shortcuts are stored in the moi.ini file which is by default saved in a central location so your typed-in shortcut definitions should automatically appear in the new version.
What won't appear automatically are custom command files that you may have installed by copying them to the \commands sub-folder. Those need to be copied into the new beta's \commands sub-folder to be installed for the new beta as well. That script copier utility will just automate that by copying any extra files it finds in v1's \commands folder over to the new beta's \commands folder.
