Not sure if this as been asked/discussed before, so sorry if you have already made a reply to this question.
When creating a standard circular rad, then the rad produced is added correctly to the solid, as in this simple example.
When I change this to a straight corner rad, then the rad is not actually produced as part of the solid, just the surface(s), as seen here:-
Is this a problem with the geometry library, or is this something you would need to fix up yourself at some time?
- Steve
