WIP - "Aurora" Cruiser
3465.3
Adding the tubes for the helix and axis. I draw two circles, and extrude them. Then, I separate the surfaces of the volume, and I cut and fillet them.
Then I draw the surfaces of the projecting areas and other details
Then I draw all the circles of the portholes, and I open them on the surface of the hull with Edit-->Trim
Finally I apply Construct-->Shell for give a thickness to the hull
Note: Talking with Michael about dudes and previous problems, he said that is better to give a thickness to the hull, and after that open all the holes and cutting all the shapes I need. In this case, would be with booleans options. ;-)
Size: 516.5 KB, Downloaded: 186 times, Dimensions: 800x588px
Size: 311.4 KB, Downloaded: 149 times, Dimensions: 800x586px
Size: 480 KB, Downloaded: 152 times, Dimensions: 800x586px
Size: 372.8 KB, Downloaded: 264 times, Dimensions: 800x587px
