Curious results
3457.1
I was just making a ring design for a customer by mainly using Surfaces & ran into a problem were the two major sections wouldn't Join.
I solved my problem by making the two sections into two Solids & then doing a Boolean Union to create what I needed.
But it's made me curious as to "Why" the Surface version wouldn't work this time around, as I've used the same workflow previously without problems?
I thought I'd read that there was some tweaking of certain parts to the Join mechanism, so was just wondered if this is now because of that??
Hopefully it's not something serious like a bug that's appeared this late in the game.
As I said, I've already solved my own problem, but figured you'd want to see both files anyway.
regards Colin
