Boat building
345.14 In reply to 345.8
Schbeurd wrote:
> By the way, Michael, is it normal (!) that if you have several non joined surfaces
> (or different objects) and that you select a curve on one of them and press
> CTRL-A, MoI will highlight all curves on the selected surface and all the other
> surfaces, not the curves ???
> Maybe not a bug, but at least some "unexpected" behaviour...
Well, this was intentional so that Ctrl-A / Select all would behave equivalent to dragging an area selection around everything.
But I think that you're right - if you have an edge or face sub-object selection it is probably more expected that select all will only grab those other sub-objects instead of everything else in addition to that.
I have changed select all to behave like this for the next beta.
