drawing arcs
3437.1
I was unable to find, by searching this forum, much about arcs, specifically as it relates to the following questions.
1. Is it possible to constrain arc drawing, to a particular 3d plane in the 3d view port?
2. Is it possible to rotate an arc, onces its drawn, about an axis?
3. How do I draw the RED arc when its not constrained by one of the Orthographic projections, as illustrated in the attached pic.?
p.s. the cube in this pic is basically a skeletal reference for positioning the existing arcs, similar to what you refer to in the Moi command reference, under the topic, Construction lines.
Size: 38.4 KB, Downloaded: 47 times, Dimensions: 696x635px
