Sweep-Problem
3431.3 In reply to 3431.1
I guess that probably the part you don't like is that with auto-place mode your profile is centered around the rail instead of hanging off to one side of it?
So to fix that you will want to do what I describe above, and position the profile so that it is actually touching the rail and hanging off to the side that you want, then when doing the sweep it will be in that position instead of centered.
In the future I want to add some adjustments to auto-place mode so that you could do something like have an origin point show up that you could drag around. But placing the profile to be touching the rail should let you get what you need right now.
