After a little break I've found time to play around some more. I love the background image support Michael, it works great that you can bring them to the front and alter the transparency. I've made good use of the array tool as well, and it works very smoothly. This is a hydraulic connector I use at work for subsea connections up to 15,000psi and 10,000ft. I'll do all the threads as inserts because it really starts to bog down once you start adding alot of threaded fasteners and such, then all the pressure seals. Render in XSI.
