Problem with Types -> Selected objects
3392.3 In reply to 3392.1
Hi rado, another workaround that you can use is to set up a keyboard shortcut and put in this as the command part:
script:moi.ui.updateBrowser();
Then when you push that shortcut key, the "Selected" and "Unselected" sub-categories under the Types section should get updated to their proper state and can be used.
