I can't export or "save as"
3382.4 In reply to 3382.2
I am running 1.1 and 2.0 beta. I open a 3dm file and select the object. Then I go to File/Save As/ and stick with the same file name, but change the type to LWO. I hit save and the box closes. No Meshing Options dialog opens. I check the folder destination and there no new file.
I'm running an anti virus program and I changed the exclusion settings to not monitor both MOI.exe files for the two versions. I restarted MOI but no change for file types OBJ, FBX, LWO or 3ds. I tried the other formats and I COULD save SAT, STP, IGES, STL, and SKP. The SKP save did activate the Mesh Option dialog. That's the only time I saw that box.
I purchased MOI primarily for its OBJ and LWO file conversion and meshing export options, and now that's the part I can't use. Any other ideas?
-Paul
Size: 16.8 KB, Downloaded: 35 times, Dimensions: 232x147px
Size: 36 KB, Downloaded: 66 times, Dimensions: 593x442px
Size: 62.3 KB, Downloaded: 33 times, Dimensions: 786x605px
Size: 18.1 KB, Downloaded: 30 times, Dimensions: 240x179px
