3 point arc tool
3380.3 In reply to 3380.2
Hi Michael
I guess yes i am meaning a snap point that takes into account the y axis. So I can understand how that might make more confusion than it helps. It could come under the symmetry draw helper, sounds like a good way to group changes of tool behavior. I am interested in how that develops.
Another example of how to do this is the bend tool used in spaceclaim. Basically you draw a line the use the bend tool to drag it into an arc. You can also put numerical values in. This allows me to define the start end points and then drag out an arc to fit without the end points moving. This is quite cool because you can make a box for example then drag out some arcs to give it form without the corner points moving. Also this works on 3d solids in spaceclaim.
kind regards
Jamie
