scaling objects
3377.8 In reply to 3377.6
Hi Val,
> I was hoping there be a keyboard shortcut to just use the edit
> frame, the 1D tool takes awhile to setup.
No, there's no special keyboard shortcut for the edit frame to do a 1D scale in some special direction - but that Scale1D command only takes 2 clicks for the setup, one click to define the scaling origin and then a second one for which direction. That's not really very much to set up.
If you have to do a lot of 45 degree angle scales, you might want to instead set your construction plane to the angle that you want to work at - the edit frame is not only fixed to the world orientation, it actually uses the orientation of the ortho views which can be adjusted by setting the current construction plane.
The construction plane tool is under View > CPlane, here:
> As for the hidden line display this works for objects that
> are already selected as I am aware.
Actually when you have it enabled, it works for all objects, selected or not - any edges that would have been hidden will become visible with a faint dashed line, and they are also able to be targeted for selection, kind of like x-raying through to reach edges that would have normally been hidden.
> However, a wire frame display, or even better
> transparent display would be extremely desirable.
Well, the hidden-line mode actually gives you access to all the wires that would otherwise be hidden, so it's basically the same as a wireframe mode, as far as being able to select wires goes.
But if you want you can also hide all faces so that only wires are visible, that's another way to get a wireframe view currently.
If stuff is getting in your way and obscuring your view, really that means you are not using the Hide command enough - hide those things to get them out of your way.
> Also, it would be nice to disable point relations for locked objects.
Check out the Options dialog for various options, that one is included there, under Options > Snaps > Snap to locked objects :
