Pulling my hair out with simple inset
3352.9 In reply to 3352.2
Hi Jamie, just a quick note:
quote:
I would project the curve use the projected curve to split the surface using the trim command then extrude the surface not the curve inwards.
The Trim command actually has stuff built in to it to project planar cutting curves itself, so there is no need to do the projection as an extra step beforehand.
It actually makes things a bit easier for the Trim calculations if you do let Trim do the projection itself.
