Exporting to Blender
3343.1
Hello:
I think that I´m not very skilful when I try to export any object from MoI to Blender.
I usually get bumped or rough areas in my surfaces.
Steps I follow:
Into MoI:
I export the object in *.lwo format.
Output: Triangles only
Weld vertices along edges: unchecked
In Options-->Import/Export--> LWO options: Lightwave
Into Blender:
I use the Blender importer posted here
Well. I don´t know if it´s necesary to have any settings into MoI before exporting, or in Blender after importing.
I put an example, with a screenshots and the 3dm file. If someone can help me.... :-)
This is the surface of a hull I was drawing.
The surface is built by Loft with Loose and 5#points (First doubt. I don´t know if there aren´t points enough)
1.-Export options
2.-Original surface
3.-Control pointd of the surface
4.- Weird result in Blender :-(
EDITED: 23 Feb 2010 by DAVID
Size: 741.2 KB, Downloaded: 130 times, Dimensions: 1400x1023px
Size: 516.4 KB, Downloaded: 89 times, Dimensions: 1400x1026px
Size: 574.1 KB, Downloaded: 67 times, Dimensions: 1400x1026px
Size: 192.9 KB, Downloaded: 142 times, Dimensions: 1400x1025px
