Joined Surfaces vs. Solids
3321.9 In reply to 3321.8
Hi Surly.
Setup this shortcut script and it will show "Naked Edges" which is where the joined surface is not making a solid. If you rebuild the surfaces where the naked edges appear, it will make a solid. Remember to zoom in on the areas to be sure that the surfaces are good.
script:var gd = moi.geometryDatabase; gd.deselectAll(); var breps = gd.getObjects().getBreps(); for ( var i = 0; i < breps.length; ++i ) breps.item(i).getNakedEdges().setProperty( 'selected', true );
