Hi Danny, yeah currently extrude for surfaces is limited to only work on a single unjoined surface.
I do want to update it in the future to work with a joined surface as well, but currently you have to separate such things into individual surfaces first, and then extrude them. You can do a batch select of them instead of extruding them one at a time though.
The worry I had about extruding a joined surface automatically was that you could pretty easily create some messed up shapes if you did something like selected a box and then tried to extrude the whole box in one single direction. That would create something with degenerate flattened sides.
That's the part that is kind of harder to work out - trying to automatically figure out which kinds of joined surfaces would be ok to extrude and which would not. Maybe I will just not worry about that, but that was the issue.
