tesselation question, special imnporter plugin to cinema4d
3314.9 In reply to 3314.7
Hi stefan,
> the rhino files comes in very nice and clean from all our
> models and testers, so we are quite happy with the rhino
> mesh export.
Are you only working with very simple models or something?
Rhino has a tendency to create quite messy meshes, there are a lot of people who use MoI only for the purpose of getting a higher quality and cleaner mesh (including using n-gons) than what Rhino is able to produce.
Problems with Rhino's mesher are pretty well known, and are discussed frequently in the Rhino newsgroup.
Here are a couple of comparisons in meshing between Rhino and MoI from some other people:
http://www.renderology.com/?p=144
http://forums.luxology.com/discussion/topic.aspx?id=23798
There you can see some direct side-by-side comparisons between the meshing, and it is so easy to see how messy Rhino's output is, and what a nice benefit it can be to the wireframe appearance to generate n-gons rather than a whole bunch of triangles.
Cinema4D has good support for n-gons so it is kind of a shame to not make use of it...
