Hi Grendel, one thing that might be more typical would be to have a "deselect inside" mode that would be used instead of a "select everything outside" mode.
That way you could do a "select everything outside" by doing a select all + deselect inside the circle, and you could also do other things like make several swiss cheese like empty selection areas instead of only one deselected area.
> On the any close curve shape I am struggling to see a use
> for it without alot of forethought. If I had something with allot
> of unique selection criteria I guess it would be handy.
Well, the part that could be good about it would be that it would cover selection by a circle as well.  Would it be too weird if you had to draw the selection circle beforehand as a regular curve object?
Otherwise, if doing a kind of "drag a selection circle" mode like you were mentioning originally, it would probably be something that would occur in screen space with a drag of the mouse, so probably there would not be specific radius values and stuff available for that.
But being based off of a curve would let you use any variety of object snaps or drawing tools to build the outline...
