Octane material ball made by MoI 3D
3265.12 In reply to 3265.6
Hi Micha,
> Boolean without intersecting surfaces? Is it possible?
Yes - in MoI you can boolean away an object that is completely contained inside of another with no intersecting surfaces, to make a solid that has an inner void cavity.
You may not be used to that since it is not possible to do that in Rhino.
You can also use Shell to create that kind of void cavity as well.
