Just wanted to know if there is a designated place to report bugs (similar to the boolean problem)? Or should I just post in the forums? The latter seems better as it might help better to inform others of the problems.
While we're on the subject of bugs. I have another to share.
I'm having a strange problem when working with a Helix curve. If I create a Helix curve then another curve (any form) and try to rotate/scale/adjust the curve (not the Helix) it causes my system to slow down dramatically (can take up to a couple minutes just to rotate/scale/adjust). If I hide the Helix, I can work as usual on the other curve without slowdown. So apparantly only when the Helix is visible.
