New Jan-18-2007 beta available now
325.55 In reply to 325.53
> If I understand you well MoI is currently able to reduce and move a
> curve control points properly while maintaining general shape of curve?
Hi Petr, yes there are a couple of different techniques that I can use to do this.
For improving lofting it is a little trickier, since it has to be done in a synchronized way to a whole set of curves, not just one. For instance if one curve needs to have a point inserted, the other curves also need to insert that point so they stay synchronized and can more easily create a simple surface when they are combined through lofting.
> If Yes I think it would be good idea to write an interface for such command
Yup, this would be the rebuild command, several people have already requested it. It will definitely happen at some point but I'm not sure when yet. Ideally this command would allow you to tell it either a number of control points or a tolerance value and it would create a new curve that followed the shape of the old one.
> which could simplify a complex curves that originate as a result of using offset,
> trim (pseudo project/pull) or sketch commands and which are to be used for other
> modeling tools (extruding, sweeping...).
A slightly different version of this is actually already happening in the Freeform/Sketch command - if you turn on control points of a sketched curve you should see that they are pretty sparse.
