New Jan-18-2007 beta available now
325.18 In reply to 325.11
Hi Mr Braun
> For Michael, little WISH:
> 1) U can add some slider to move the image on x,y,z and one for scale it?
I'll be working on a way to edit the images for the next beta.
What I'm going to try to do is enable direct editing of the images when you are inside the image command - I mean that you will be able to click and drag on an image to move it, and there will be some kind of frame that will appear that will allow you to scale it.
That's the concept anyway.
This should also be a good trial run for an object frame that will eventually become a different way to scale and rotate regular objects as well.
