Hi Ryan, one other note though - you are going along with the right general idea here, to build the thing as a larger piece like this:
and then to slice off the ends, rather than trying to draw the sliced off end first and then try to create surfaces from that.
So you're definitely going in the right direction, but in this case your starting surfaces didn't end up too good, partly because of a problem in sweep in v1 but I'm also not sure if you might have had a little wiggly area in some of your starting curves.
If you are going to give redrawing the thing a try, you might want to post your initial curves here so I can take a look and maybe give some advice on that initial shaping.
