New GPU Render: Arion - FryRender
3240.3 In reply to 3240.2
I'm impressed by the idea to get all hardware working - CPU+GPU+slaves. I would be glad, if someone would develope an engine that will use this all, but allow biased rendering too. I hope Vray will do it. At the moment I used Vray for Rhino daily and I have no problem to get speed&quality. The speed per little renderfram (5 machines) is not bad, but a speed boost by factor 100 could be more than enough. Seldom an image needs more than an hour (high res interiors).
I afraid, using an unbiased GPU engine instead the current slave solution could be not the big deal, since unbiased rendering is much slower. Important for me is, that it work for complex interiors too. Exteriors and product shots can be quite fast done already today.
Visualisation for Designer and Architects | www.simulacrum.de
