Altering or deforming Moi objects in a polygon app (C4D)
3238.20 In reply to 3238.19
Hi Michael, I exported triangles at Angle = 10, DLT = .25. The shading artifacts are there. I used the Magnet "circle" setting with the radius matched to the headrest but pulled a lesser distance. It appears to torque the edge polys too much.
> If your polygons have too much variation between each adjacent one, that can tend to cause
> shading artifacts where the smooth shading trick does not work as well to make those flat
> pieces appear as if they were a smooth surface.
Leonard
Size: 224.9 KB, Downloaded: 36 times, Dimensions: 450x729px
Size: 305.1 KB, Downloaded: 26 times, Dimensions: 511x741px
Size: 278.8 KB, Downloaded: 27 times, Dimensions: 539x532px
