New Beta
3176.6 In reply to 3176.5
Hi Brian, do you mean that the Template file thing is confusing you?
You can do the first step of just adding the styles you want and then saving that to a 3DM file, right?
After you have done that, you just go to the Options dialog, which you can launch by pushing this button:
You will want to fill in the option that says "Template file", push the little button at the end of the line to get a file picker dialog, then pick the file you saved that has your styles in it:
That's it, you're done - the next time you start MoI your initial style list will be loaded from that file. If you want to update them, just update that file.
MoI will need to access that file every time it starts, so put the file somewhere that you are not likely to delete it. If you delete it, then MoI won't be able to find it at startup and it will revert to the stock set of styles if that happens.
