Hi Brian, a bit later today I will post the script copier utility which will copy any scripts you had installed into v1 over to this new beta's install folder.
Basically each plug-in is set up by a shortcut key and also the plug-in script and UI files.
The keyboard shortcut part comes over automatically into the new beta (because it is completely contained within moi.ini), but the script and file parts are separate files that need to be copied over.
So for example with Nudge, there is a file named Nudge.js and you need to copy that into the \commands folder under the new beta's install folder.
Once Nudge.js has been copied into the new beta's \commands sub-folder, then that will make the Nudge command available to the new beta.
