Hi Burr, so I tried hacking out the kink splitting from the tolerance based curve fitter, and the results are not at all good, just like I had thought.
So for example here would be the result of applying it to a rectangle:
Notice that having a corner in the middle of what is intended to be a smooth accurate fit throws a monkey wrench into things and causes undulations and wrinkles. As you tighten up the tolerance, those things get reduced in size but are still present near the corner spots.
Are you still sure you would want to have that?
I guess I could call it something like a "mess up your curve in weird ways" option... ;)
But that's kind of what I mean by it not being a good combination with an accuracy-based fitter.
