Llittle Surf headache
3158.4 In reply to 3158.3
> In your image I see only one? Or they are very close?
It looked like they were mirrored copies... So either mirror or if they are not identical then repeat the same process on the other side.
If after untrimming the surface is not large enough to cover the new expanded trim outline, you will need to extend the surface somehow, possibly by scaling or stretching control points.
