Surface curve segment lines visible in C4D
3147.6
Thanks, Michael. Yes, I reconstructed the four principal splines with Moi3D and it definitely improved the quality.
"Once you extrude something in MoI that is made up of a bunch of little lines, it generates a bunch of little planes in the extruded part rather than a smooth extruded surface."
That's topical. I imported the all Moi cushion into C4D and at the rounded corners, the little planes are not behaving in a desired way. The normals are fine. Is this right or am I doing something wrong?
Key to pics.
Pic a, the wire.
Pic b, the light to the right "off", light above & behind "on".
Pic c, the right light on, light above & behind off.
Pic d, both lights on at same intensity.
Pic e, both lights on at same intensity but doubled.
Pic f, top view of scene
Leonard
Size: 80.4 KB, Downloaded: 37 times, Dimensions: 825x576px
Size: 43.3 KB, Downloaded: 32 times, Dimensions: 770x576px
Size: 44.5 KB, Downloaded: 18 times, Dimensions: 768x576px
Size: 42.5 KB, Downloaded: 17 times, Dimensions: 770x576px
Size: 40.8 KB, Downloaded: 26 times, Dimensions: 768x576px
Size: 48.5 KB, Downloaded: 33 times, Dimensions: 594x401px
